IVI Compliance Package 2.0
I'm having a similar problem and I've done all of the above accept reinstalled LabView.  I get the following error when call a IVI driver programmatically or when I try to run the INI to XML converter:
IviConfigServer.IviConfigStore.1:Deserialize failed.  Can not create XML DOMDocument. Please check your XML parser installation.
As I said I've uninstalled ICP 2.2 and used the Shared Components Cleanup Utility, rebooted and then reinstalled ICP 2.2.  I've even reinstall MSXML parser 3.0 sp5.  I'm still getting this error.  Any other ideas or should I just bite the bullet and reinstall LabView?
mmccarty
NRAO
Message 11 of 11
(992 Views)
