IVI DcPwrSupply Issue on Test Stand 3.5
I´m trying to use an HP 6652a Power Supply thru it´s IVI Driver in TS
I insert the step into the sequence, configure it, and an -30002 error apears.
Here is the error log.
An exception occurred calling 'RunStep' in 'ISubstep' of 'TestStand Ivi Step Types'
An error occurred while executing the step.
Component Works IVI Control Error: The IVI Configure operation failed for logical name 'AGILENT_6652'.
Details: An invalid argument has been passed to a property or method. (OVPLimit)  (CHANNEL1) Invalid value for parameter or property. OVP Limit [IVI Error Code:  BFFA0010]
Source: TSIviStepTypes
Using the NI Spy show that 2 commands fails. (Spy_1_NOk)
But if I send the same comand using the "Validate" button, and the soft panel. it works seamlessly.
The sw installed are:
ICP 4.4
Test Stand 3.5
Agilent HP6652a IVI 3.2.2.4
Any Idea?
Message 1 of 1
(3,053 Views)
