IVI Deriver in MAX
I installed an IVI com driver for an anritsu signal generator and it does not show up in MAX.  Why not?
Bill F
(3,383 Views)
Try to install any other IVI-COM drivers such as from Agilent, to check if they appear in NI-MAX.  If other drivers correctly appear in NI-MAX, it may be a driver-specific problem of Anritsu driver due to such as incorrect registration to IVI Configuration Store.
Also what NI-MAX version are you using?  Older NI-MAX versions do not check IVI Configuration Store and then IVI-COM drivers are not shown.
(3,376 Views)
Will try that.  I'm using MAX 4
Bill F
(3,367 Views)
