Efficient,
I have a test system with two NI-DMM 4070 and two Agilent power
supplies (PS) E3646A that are used in parallel. I have configured them
in MAX to use the very same instrument driver (of course the DMM driver
for those and the power supply driver for the other one) and to use
differen logical names and adresses (e.g. driver sessions). It
workes flawlessly.
In my code I adress them as 'DMM-U' and 'DMM-I' and as 'Mains', 'Batt' or 'Akku', respectively.
Just in Case: The A3646E are two-channel PS, where each challel was given a logical name.
From the help in IVI driver session: "A driver session defines a set of
properties for use by IVI instrument driver software modules, such as
initial configurable settings for attributes, virtual name mappings,
simulation settings, and so on. Multiple driver sessions can exist for
each instrument driver software module. "
And: "A hardware asset is a physical device that performs a measurement
or stimulus function. The term hardware asset includes instruments, but
may include other types of hardware as well, such as switch matrices
and probes."
I can't remember the actual steps to create this setup, but I can assure you that it can be done.
Greetings from Germany!<br>-- <br>Uwe
