IVI/VISA programming for power supply PXI 4110
I trying to find some sample code(MS VC++ 6.0), implementing an application using IVI/VISA APIs for Power supply PXI 4110 etc.
Please let me if someone can provide his.
Is "niDCPower_init" is NI Driver specific API?
Subhash
(3,719 Views)
subhashv,
First, the niDCPower_init is unique command to the NI-DCPower driver(IVI instrument specific driver).  If you are looking for a driver that will allow you to interchange multiple power supplies then you need an IVI class driver.  Meaning you could use a National Instruments power supply one day and some other power supply the next day by making minimal changes to the code.
Second, while searching for an example I came across DC Power Supply Visual C++ Code Samples.  Here is also a link to National Instruments NI-DCPower Power Supply (IVI Class driver), in case you were interested.
A_Ryan
AES
(3,692 Views)
Hello subhashv and A_Ryan,
        All of the IVI Class drivers that NI Provides are available in the IVI Compliance Package.  More information on IVI drivers can be found at ni.com/ivi.
Cheers,
NathanT
(3,681 Views)
