IVI driver program using NI TestStand and NI-MAX for TDS1002B
I am new to IVI drivers programming  and I was successful in initializing TG5011 function generator using IVI driver from NI-MAX & NI TestStand.
However, I am finding trouble in Initializing a new Oscilloscope (Tektronix-TD1002B) that I want to set up using IVI.
I have created driver session for Tektronix scope in NI-MAX. I believe I get an error in NI TestStand because of driver compatability as TDS1002B is not listed in the supported models section in NI-MAX.
Please help me to resolve this and please post the relevant IVI driver for TDS1002B if there is any.
(4,647 Views)
Hi Sahiti2013,
Is this the driver you are looking for? Robot Happy
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E94FE659CE034080020E748...
Kind Regards,
(4,629 Views)
Hi Laurence,
I have already seen the driver in the link that you pasted.Thank you for your time.
I just need to be sure if it can be used with measurement explorer and NI Test Stand.
or If I can download the same driver and use the dll file in NI-MAX IVI configuration.
Many Thanks
Sahithi
(4,620 Views)
Yes it works fine - it appears as tktds1k2k under Driver Sessions in MAX, and I have checked it appears in TestStand too.
Kind Regards,
(4,617 Views)
That's really great.Thanks for your help.
Sahithi
(4,611 Views)
