Image capture with Hauppauge WinTV to IMAQ
I found a thread
http://forums.ni.com/ni/board/message?board.id=170&message.id=7351&query.id=0#M7351
which mentions that someone had success doing image capture with a Hauppauge WinTV bt878 based card.  I am trying to use IMAQ image averaging software along with this board, and need a way to capture images from the board within Labview.  However, I could not find the example code mentioned in the above post.
Has anyone had any luck in making this or a similar card work?
(3,510 Views)
Hi Rgann -
It looks like the VI mentioned has been taken down in the five years since it was posted.  NI doesn't provide any LabVIEW drivers for third-party devices, and I'm unable to find any currently on the DevZone.  I recommend contacting Hauppauge for more information.  They may at least be able to provide you with a driver API that can be called from LabVIEW.
Of course, there's always the hope that one of our forum regulars has some code you can use, too!
David Staab, CLA
Staff Systems Engineer
(3,498 Views)
