Imaq image acquiring problem
I am using webcam. When I am try to interface the camera into the labview by using Vision Acquisition block(which is available in vision and motion toolkit), it showing the error as " The Following error occur while configuring the acqusition: NI-IMAQdx: (Hex 0xBFF69026) License not activated." But I have license to activate the toolkit and also i already did that.
one more thing, my Camera works fine in NI Measurement and Explorer. Kindly guide me How Can I overcome the error and How to move.
Please I am awiting for your replies.
And finally, I tried one VI Also. in that VI also getting some error. Here I attached the error VI image
(4,890 Views)
Check your interface name
This error is generated when the IMAQ Init VI is called with an incorrect interface name. In MAX, the NI-IMAQ driver assigns an interface name to each IMAQ board in your computer, starting with img0, then img1, etc., in the order in which the boards are installed. If for example, MAX has img1 set for your interface and then in your code you call the IMAQ Init VI with the interface name img0, it will give you this error.
(4,850 Views)
Also post in the MACHINE VISION board for questions related to imaging
(4,849 Views)
