Impossible to load automatically a driver of Xantrex Power Supply
Hye,
Im using a Xantrex power supply drived through GPIB with a National Instruments driver : XanM9B_IVI_Driver (installation file : LW_6_0_XFR-XHR-XPD-HPD-XT_IVI_Driver_4_0_3.exe). Contrary to all the others drivers i used, it seems impossible to load this driver automatically with the Library->Customize menu of LabWindows CVI 7.1. When i try to do this process the following message appears when i restart LabWindows :
   Warning : can not find program
(3,195 Views)
Are you sure that you are using National Instruments' driver? The installer file name for the NI's driver is XanM9B_MS.msi. This driver can be found on http://sine.ni.com/apps/we/niid_web_display.download_page?p_id_guid=E3B19B3E9353659CE034080020E74861.
Vesna
(3,192 Views)
