In the LABView GPIB-232/485CT-A operate OK.
In the LABView GPIB-232/485CT-A operate OK. I confegure EOS ( from D to X,B,10) in LABView and send in MAX command through secondary address to device conected to GPIB and it resive it. When I begin confegure primery address in MAX it is not sucsess.
What is cause that GPIB(primery) didn't recive command eos?
(3,133 Views)
Hello-
Let's verify the serial port is communicating properly:
-The VISA interactive control can be used to send strings over the serial port to an instrument (C:\VXIPNP\WIN95\NIvisa\NIvisaic.exe when LabVIEW is installed). The "Basic I/O" tab of VISAIC is a very quick way to determine the proper port. Attach a paper clip between pins 2 and 3 of the serial port and do a viWrite for a string command then do a viRead. If the command echoes back, the loopback was successful. Also, try removing the paperclip and sending a command. This time the command should not echo back.
-There may also be a problem with the cable. Most instruments require a null modem cable. Be sure the cable is not a straight through cable. The quickest way to test the
type of cable is to use a multi-meter. A straight through cable will have a connection between pins 2 on each side of the cable.
Randy Solomonson
Application Engineer
(3,133 Views)
