Incomplete Serial Message
Hi I need some urgent help, I'm making a program that sends messages between 2 PCs via a serial visa connection for a university project. Everything seems to be working properly except for some reason even though one side reports that it has sent a full message, the other side seems to be receiving it in 2 parts. They are set up to read the serial port using the bytes at port subvi, also I have set up a custom termination char of "<" with the hex code "3C" going into the configure serial port vi. I am totally stumped on this, and short of totally redesigning my serial read to concatenate the received messages I'm not sure what to do. Any help would be greatly apreciated.
(3,679 Views)
No way to help you without having a look at your wiring work. Make it simple and clean 😉 and post it here. Somebody will have a look at it...
Chilly Charly    (aka CC)
(3,673 Views)
Hi thanks for your reply, I'd rather not post it on these public forums incase someone else from my year see it but if you are willing to look at it for me ill send it to you by email. If you are please reply again, thanks. The same with anyone else willing to look at it.
(3,668 Views)
my email adress can be found on my personal infos. Just click on my name...
(3,663 Views)
