Increasing Sampling Rate for NI 9212 (No Timing Mode Property!)
I have a 8-ch NI 9212 thermocouple module. While I need to read temperature for all channels every second, it seems the default sampling rate is about 2 Hz.
I found the following web page and wanted to try changing the Timing Mode to High Speed.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIVjCAO&l=en-US
However, I could not locate the property. Here is the screenshot. I see 'Dither' in that spot instead.
I am using LV 2018 SP1 f4 and DAQmx 18.5.
Any help is appreciated!
Message 1 of 1
(572 Views)
