Initialize array with NaN
For a data recording, graphing and analyzing VI, why should I initialize the arrays to NaN after reading the data from files. I figured it is for synchronization. Can anyone give a detailed explanation?
(4,881 Views)
You posted to the wrong board. Your question has nothing to do with instrument control.
That being said, it has nothing to do with synchronization. It is generally used to preallocate the memory used by an array. This would be used along with a replace array function.
(4,878 Views)
