Initialize error fluke 6100a
I am getting the error below when I try to use the fluke initilze function from the driver.  Does anyone know why?
Error -1073807195 occurred at VISA Open in fl6100a Initialize.vi
Possible reason(s):
VISA:  (Hex 0xBFFF00A5) The interface type is valid, but the specified interface number is not configured.
Kudos and Accepted as Solution are welcome!
(3,777 Views)
which driver (NI instrument driver network?)
and which interface? bus?
greetings from the Netherlands
(3,775 Views)
       It would also benefit you if you went through the steps in the Instrument Driver Troubleshooting Guide.
Cheers,
NathanT
(3,751 Views)
