Insert Mask vector into MS2661C spectrum analyzer [Anritsu].
Hi All,
Mask Measurement
I need to Insert Mask vector into MS2661C spectrum analyzer [Anritsu].
If someone use this model of spectrum and success at inserting external mask vector
please reply.
Shmulik dekel
Texas Instruments
(3,051 Views)
Hello Dekel,
      If you are using LabVIEW, you could download one of these drivers and see if they implement the functionality that you are looking for.  The drivers are not certified or NI-supported, so their quality might be hit or miss.  Either way, you should also look through the programming and user manuals for your instrument to learn more about inserting a mask vector.
Good Luck,
NathanT
(3,035 Views)
