Install NIVISA and GPIB on Scientific Linux 7.4 64-bit
SYSTEM REQUIREMENTS
NI-VISA 15.5 for Linux software requires one of the following distributions:
http://www.ni.com/download/ni-visa-15.5/5848/en/
GPIB-488 2015
http://www.ni.com/download/ni-488.2---linux-15.1.1/5926/en/
INSTALLATION FROM THE INTERNET
You should be logged in as 'root' to perform this installation.
Pre-requiste 32-bit libraries and kernel-source
yum install libXinerama.i686 mesa_libGL.i686 kernel-devel
Install 32-bit version of libstdc++
yum upgrade libstdc++
yum install libstdc++.i686
yum upgrade zlib
yum install zlib.i686
INSTALLATION FIRST NIVISA FROM THE INTERNET
1) Download the ISO image "NI-VISA-#.#.#.iso" from the ftp site into a
temporary directory.
2) Open a Terminal (command prompt) window.
3) Mount the ISO image. This may be done by typing
"mount -o loop <iso-location>/NI-VISA-#.#.#.iso <mount-location>".
4) Make the mount location your current working directory. This may be done
by typing "cd <mount-location>".
5) Type "./INSTALL" to execute the install script, and follow the instructions
as prompted.
Install gpib driver version 15.1
BUG with NiKal
cd /var/lib/nikal/3.10.0-693.17.1.el7.x86_64/nikal
edit nikal.c
ifdef nNIKAL100_kFourParameterDoMunmap
return do_munmap(mm, addr, len, 1);
#else
return do_munmap(mm, addr, len);
#endif
#else
return do_munmap(mm, addr, len, NULL);
#endif
Compile kernel driver
updateNIDrivers
Check kernel modules
# lsmod | grep ni
nimxdfk 584221 1
nipxirmk 297697 1
nidimk 376929 2 nipxirmk
nimdbgk 459483 3 nipxirmk,nimxdfk
niorbk 120227 4 nipxirmk,nimdbgk,nimxdfk,nidimk
ni488k 224199 2
nipalk 1231884 12 nipxirmk,NiViPciK,nimdbgk,nimxdfk,ni488k,nidimk,niorbk
nikal 115446 6 nipxirmk,nimdbgk,nimxdfk,nidimk,nipalk,niorbk
(3,336 Views)
Hi Bionnassay,
Is there a question?
(3,299 Views)
