Installing NI-VISA and NI-488.2 on Mac
Hi  - I'm having a similar issue and would greatly appreciate any assistance. I'm trying to install NI-488.2 driver on a Mac to use GPIB-USB-HS to control an instrument with Matlab. But thus far, I'm unable to successfully use the driver. Here are further details:
  • MacBook Air - 10.14.1 OS
  • NI-488.2 version 19.5 for macOS
  • Hardware to be used with GPIB-USB-HS
The installation completes successfully with no error messages. It creates a directory under Applications called, National Instruments. However, running Application -> NI-488.2 -> GPIB Explorer, I get an error message popup that says: "The attempted operation failed." If I run, Application -> NI-488.2 -> Troubleshooting Wizard, I get an error message popup that says: "The Ni-488.2 software is not correctly installed on your system. Please follow these steps: 1. Restart your system. 2. Reinstall the NI-488.2 Software. 3. Run the Troubleshooting Wizard again." I have tried to do this a couple of times, with no luck. I end up with the same error message and the status shows failure at "Ni-488.2 Software Presence Verified" step.
Has anyone been able to successfully use GPIB-USB-HS with Mac OS 10.14?
If yes, could you please kindly mentioned the driver version used? And if any special steps were taken to install the driver? Thanks.
Message 21 of 21
(617 Views)
