Instrument Driver for Advantest R6243/6244
Has anyone developed the instrument driver for Advantest R6243/6244 and willing to share the driver? Thanks!
(4,175 Views)
Hi Rebecca,
There are several drivers for other Advantest products in NI's Instrument Driver Network, however I didn't find any driver that specifically matched the R6243/6244 voltage/current generator, and I didn't find anything on Advantest's site that could point me to a quick solution for you. Unless another user has developed a driver that they could give you the code for, it looks like your best bet from this point is going to be to request a driver, if you haven't already. You can do this by going to the Instrument Driver Network, and following the link to "Request Drivers". Hopefully this helps you on your way. Good luck!
Logan S.
(4,164 Views)
Hi LoganS,
Thanks for the advice. I already post driver request to NI. Thanks
(4,157 Views)
