The VXIplug&play driver for 83711B and 83712B Synthesized CW Generators and 83731B and 83732B Synthesized Signal Generators. Programming with this driver does not depend upon an I/O library specific to your brand of HP-IB/GPIB interface, thus your programming code becomes much more portable. The Visual Basic and Visual C++/Borland C++ Programming Examples using this driver are built-in to the Windows Help file for the driver. The driver is compatible with all of the following programming environments:
- Microsoft Visual Basic Version 4.0 or higher
- Microsoft Visual C++ Version 4.0 or higher
- Borland C++ Version 4.5 or higher
- HP VEE Version 3.2 or higher
- National Instruments LabWindows/CVI Version 4.0.1 or higher
- National Instruments LabVIEW Version 4.0.1 or higher
