Instrument Drivers
 i couldnt find the drivers for spectrum analyzer (ANDO AQ315B Or ANDO AQ 6319) and Powermeter (Agilent 81635A).i have searched the NI.com/ Idnet, but no use. if anybody have them please send me (Labview 8 or 8.6). Thank u.
(4,815 Views)
Don't know anything about the analyzers. A Google search turned up nothing. Are you sure you've got the right model numbers?
As for the 81635A, that's not a power meter. That's an optical power sensor. It gets plugged into a meter, and that's the driver you want. For instance, do you have an 8163A lightwave meter?
(4,795 Views)
Thanks for the reply , Please at least send me the Optical power sensor drivers if u have....
(4,769 Views)
How much experience with computers and browsing the Internet do you have? You did not recognize a link when you saw it. Click on '8163A Lightwave meter'. You will be magically transported to a place where you can get the driver yourself.
(4,762 Views)
@ Dennis Knutson
it is nothing to do with the experience , i have already downloaded through that link. but i thought Optical power sensor is different from the Light wave meter.i am not good at these analyzers and meters stuff.so, i have posted it.
(4,757 Views)
The link for the meter was an example since, as I pointed out, the model number you gave is for the sensor, not the power meter. The sensor plugs into something. What are you plugging it into? Do you know how to use the instrument? If not, you have to learn to use the instrument before you have any hope of figuring out how to program it. We can't teach you how to use the instruments.
(4,730 Views)
