Instrument I/O Assistant Crash
I am using Instrument I/O Assistant to read data from a scale through a Serial->USB conversion, using LV2012 SP1 (I've also tried this on LV2010 with the same results).
I configure the baud rate, parity bits etc, and that seems to work fine.
I add the "Read and Parse" step or a "Query and Parse" step, and then try to run the Instrument I/O Assistant.  The Instrument I/O Assistant window closes.  It doesn't throw an error, or a warning or anything.
Needless to say, the vi where I use the I/O Assistant does not run either.
Any thoughts as to why this is happening?
Seth Price, N3MRA
Lab Associate, Chemical Engineering Department - New Mexico Tech
Lab Assistant, Sodium Dynamo Project
(4,064 Views)
Personally, I think not having the assistant is not such a bad thing. What happens when you use the simple serial example? What sort of converter are you using (ftdi, etc.)? What os and version of VISA?
(4,060 Views)
