Instrument I/O Assistant causes VISA error 0xBFFF0072, VISA resource available but cannot access it
I'm running LabVIEW 2017 on a desktop PC.  The PC is connected via a USB-to-serial adapter to an RS-232 serial port on a Tektronix DMM4040 multimeter.
I place an instance of "Instrument I/O Assistant" onto a VI's block diagram. Using the Instrument I/O Assistant "wizard" dialog, I can communicate with the DMM4040 as I create the sequence of steps to be executed--e.g., Select Instrument, Write, Query and Parse, etc. If I click on the wizard's "Run>" button, the script runs fine; everything works.
Now I click on the wizard's OK button to close the dialog and render the code in the Instrument I/O assistant node on the block diagram. When this process completes, I click on the VI's "Run" arrow (CTRL+R) to execute the VI.
At this point the error dialog shown in Figure 1 appears:
Figure 1
If I close all LabVEIW programs, restart LabVIEW, open the VI, and then run the VI, the program runs normally; no error dialog appears.
If I now open the Instrument I/O Assistant wizard, and then immediately click OK to close the wizard, I get the error message again when I run the VI.
So it appears the Instrument I/O Assistant code has a bug(?) that is perhaps failing to release system resources associated with the virtual COM port the DMM4040 is using, and this is causing the error.
(2,834 Views)
What is the point of using Instrument I/O Assistant?
(2,814 Views)
