Instrument I/O Assistant isn't in palette
Hello, I installed Instrument I/O Assistant but when I go to palette to use it doesn't in palette. I searched in all computer but I can't find it, although it appers installed in NI package manager. I'm using the last version of LabVIEW.
I read constantly about the device driver CD. I don't understand this, I didn't find in NI package manager, is the Instrument I/O Assistant be installed from CD or only works using CD?
When I read CD I think in a CD, like a DVD.
(1,723 Views)
I've never used I/O Assistant, but here's some suggestions.
The reference to the CD/DVD is from when LabVIEW came on several disks and one disk was all for drivers (NI_VISA, etc..)  now its all done through NIPM.
What version(s) of LabVIEW do you have installed and what version of I/O assistant did you install?  Have you rebooted the system?  It might not take effect until you restart all NI software.
From the link it should appear in your pallet.
https://www.ni.com/en-ca/support/documentation/supplemental/12/instrument-i-o-assistant-explained.ht...
Make sure you have the Block Diagram open, then look for the Instrument I/O heading.  You won't see it from the Front Panel pallet!
Hope that helps.
Craig
(1,684 Views)
Thank you!
Finally, I understand what happens. I have tried with LabVIEW 2019 and works at the first time, it is in the palette. I was working with the last version of LabVIEW 2021 spring. I thing that it is a bug.
Thank you so much.
(1,670 Views)
Hi, I did the same thing that artodetodo did.
I can't find the instrument assistant VI.
Can anyone at NI tell us how we can configure what we downloaded and installed to work in Labview?
(1,384 Views)
