Instrument I/O Assistant (sending command from labview to arduino)
I am a beginner in Labview. I would like to control the intensity of AC loads using labview. In this case, i would prefer to use instrument I/O assistant. The instrument I/O assistant in labview will have to send a command to Arduino. The intensity will be controlling by using slider in labview. How to write the vi for this example? Please advice.
(4,554 Views)
In the thread for your other post, you were told that LabVIEW installs by default example programs on how to use LabVIEW with serial port.
Have you bothered looking at that?
You need to do some work on your own.
(4,541 Views)
