Instrument I/O assistant problem
I am trying to interphase Hameg HM7044 programmable power supply with the pc, I am able to communicate with the instrument after i installed the drivers, but unfortunately the Instrument I/O assistant gives me an error each time saying that it was not installed correctly. I am using labview 2016, and i tried to uninstall and reinstall the instrument assistant but it still shows the same dialogue box or error.
Also, i see only an instrument I/O assistant version 20.0 online, i guess this isn't compatible with the labview 2016 version, is there a instrument assistant for the 2016 version that i can download from somewhere? or if i could solve this problem in someother way?
thanks in advance
(1,698 Views)
HI,
Instrument I/O Assistant supports labview starting from version 2017.
NI-IIOA 20.0 Readme
(1,573 Views)
First search for an existing driver.
I did not yet search but remember it existed. The io assistant only helps in a template.
greetings from the Netherlands
(1,571 Views)
