03-08-2023 03:44 PM
Until recently, I have been able to use my NI 1075 chassis and all cards in it with no issue. Now, I am unable to open the soft front panel of the NI-PXIe4110 power supply through InstrumentStudio. I am also unable to operate any of the cards through Python, such as the NI-PXIe2535 switchmatrix (using niswitch).
I have performed the following troubleshooting:
1. Confirm that 4110 and 2535 exist in NIMAX
2. Confirm that I can operate both through legacy soft front panels (no fuse blown on 4110)
3. Reinstall all drivers for the following: nidaqmx, nidcpower, niswitch, IVI compliance manager
4. Reinstall all nimi python API packages
5. Rebooted multiple times (both PC and chassis)
Any help on resolving this issue would be greatly appreciated.
Sincerely,
Dorino
03-09-2023 02:45 PM
Dorino,
Were there any changes (hardware or software) which occurred prior to these failures?
It would be helpful to know specifically what driver versions you had before and after and the specific error codes you are seeing, with minimal reproducing steps.
Some additional troubleshooting steps:
Additional questions:
