Instruments not accessible via E5810A on VISA 5.4
After upgrading to the latest version of LabVIEW and VISA I am having problems connecting to my GPIB instruments on a E5810A gateway. At first I tried to configure everything the same as in my old installation (enable the tulip dll, manually add instruments with ip + gpib0,x). When I click validate I get an error 0xBFFF0011 telling me that the device is not connected or that the location information is not correct. After that I researched the forum and read these threads and the kb article:
http://digital.ni.com/public.nsf/allkb/C6ADD4D65354570086257AA1002F5F67
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/After-applying-fix-for-using-Agilent-E5810A-L...
https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/After-applying-fix-for-using-Agilent-E5810A-...
I have no real clue on how to get this working again. I tried to enter gpib0,1 or gpib0::1, disabled and re-enabled the tulip dll... When i go to the website of the gateway and list the devices there they are all found.
When I just enter GPIB0 as device MAX can open a VISA session but I am not sure where it connects then?
I am running Windows 7 64bit, LabVIEW 2012 SP1 f4 and VISA 5.4, MAX5.5.0f0
Any help will be much appreciated!
Message 1 of 12
(6,706 Views)
could you post a screenshot of the website of the gateway and of MAX. A MAX-Report would also be nice.
Kind regards
Heinz
Message 2 of 12
(6,683 Views)
...here you go.
I tried the old way (gpib0,1) and the new way?? (gpib0::2). When creating the LAN resource the dialog doesn't let you enter the "::" I did that after creating it. Both give the same error when I try to open a visa test panel:
The connection to just "gpib0" can be made without a problem.
The screenshot of the devices connected to the gateway:
Cheers,
Christian.
Message 3 of 12
(6,669 Views)
Hi Christian,
I'm sorry, I have to tell you this behavior is a Known Issue, which has not been solved yet. You can look it up here:
http://www.ni.com/white-paper/14172/en#375426_by_Date the ID is 375426
I'm sorry for the inconvenience you're experiencing.
Kind regards
Heinz
Message 4 of 12
(6,644 Views)
Thanks Heinz.
Do you know of any plans to resolve that issue?
Christian.
Message 5 of 12
(6,636 Views)
yes of course, we will fix this issue. But I can't tell when - I hope in the next version of VISA.
Kind regards
Heinz
Message 6 of 12
(6,633 Views)
Would you be so kind and post that info here? I don't want to upgrade to the next version to find out that the problem was not fixed.
Christian.
Message 7 of 12
(6,628 Views)
Hi again,
I will if I don't forget to. But you can also find out:
In the readme of the next version should be a section like this:
Known Issues and Bug Fixes
For a list of Known Issues of NI-VISA 5.4, visit ni.com/info and enter the Info Code NIVISA54KnownIssues.
For a list of Bug Fixes for NI-VISA, visit ni.com/info and enter the Info Code NIVISAFixList.
If the ID is not listed in the NIVISAFixList it is not fixed, yet.
Best regards
Heinz
Message 8 of 12
(6,623 Views)
Hi everybody,
I just want to add that I have nearly the same problem with the TAMS L488 LAN-GPIB Adapter.
Meanwhile I started a support request at NI and they could duplicate the problem in their lab and created a "Corrective Action Request" for their development team to fix this issue.
Until the problem is solved I work with NI-VISA 5.0.3 or older. Maybe this could be a temporary solution for some of you, too.
Best Regards
SP
Message 9 of 12
(6,536 Views)
This issue (#375426)  shows up as known in VISA 5.4.X on this list:
   http://www.ni.com/white-paper/14792/en/
But shows up as a 5.4 bug fix here:
   http://digital.ni.com/public.nsf/allkb/82A6CC08D574B40E862578EA0067D8A3
I'm fairly confident it's still present in 5.4.  Any word if it really will get fixed in 5.5?  It's a big deal for people who have gateways that can't be used with current software.
Message 10 of 12
(6,340 Views)
