Interfacing of Aaronia Spectran V6 software RTSA Suite Pro with LabView using HiSLIP-SCPI Server block
Let me make this as simple as possible here.  Enter "ASCII \s" into your web browser and it will respond with Space as they are one and the same for the interpreting SCPI equipment.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 11 of 14
(657 Views)
Okay. Thanks
Message 12 of 14
(641 Views)
I want to stream data produced in RTSA Suite Pro software in Labview. So, which data format I need to stream it in Labview. Actually I want to produce waterfall graph through this data. Also share method to produce waterfall graph in Labview.
Message 13 of 14
(579 Views)
In addition to above questions. This is the data I got in Labview. Is it possible to produce waterfall graph from it? If yes then how?
Message 14 of 14
(561 Views)
