Intermittent ibrd EABO errors
I am developing a system to send and recieve from an instrument, i now have it writing to the instrument correctly all the time,
but when i want to get STAT? or *IDN? it works intermittently,
I analysed what was being sent in and out, and i found that when it gives me an EABO error, its because it has only sent the first character,(ie if i sent *IDN? it would only send *) why is this? the timeout is set to what the books says, the command is correct, but it works sometimes, is there anyway i can force it to send it 100% of the time?
Cheers for any help
Justin Pyfrom
(4,218 Views)
what version of 488.x use your device?
have a look at the following for the error description:  http://digital.ni.com/public.nsf/websearch/2FA525A8585A92E9862566EE002A3755#EABO
(4,212 Views)
version 488.2m.
As it turns out,ive now got it working 50% of the time, it works then fails then works ad infinitum.
Have u heard of this before?
cheers
(4,210 Views)
Got the problem solved, i just had to do a readdress after every read/write, using ibconfig at the top of my code, where i placed ibdev
Cheers for the help tho
Justin
(4,200 Views)
