Intrument I/O Assistant question
I have a GPIB-USB-HS hooked up to my laptop and I am trying to use the Instrument I/O assistant to talk to a Aeroflex Spectrum Analyzer.  I pull the Instr I/O assistant out onto the block diagram, it gives me a status bar like it is going into the properties.  Then nothing happens.  I right click and try togo to properties and still nothing.  Am I missing something here? I haven't used the I/O assistant yet so I am unfimiliar with it.  I thought it was similiar to the DAQ wizard.  Oh I am using LabVIEW 7.1 and GPIB 488.2 Ver. 2.42.  Also are there any drivers for the Aeroflex 6825 series that work? The ones I have were for LabWindows, when I converted them over to labview they stopped working....
Chris
Message 1 of 12
(4,615 Views)
You mention the 488 driver but what about NI-VISA? Is that installed?
Message 2 of 12
(4,594 Views)
I have the same question Chris ( NI GPIB-USB for LabView I/O Assistant ).
Did it work after installing NI-VISA ?
Peter.
Message 3 of 12
(4,218 Views)
You will definitely need NI-VISA to use the Instrument I/O Assistant.  The version you need depends on the version of LabVIEW you are using.  Here is the compatibility chart: http://digital.ni.com/public.nsf/allkb/CF4279A34F855AB186257B1F00003B82.
Cody A.
Message 4 of 12
(4,196 Views)
Thanks, thats clear enough.
But the link doesn't work, please review.
Message 5 of 12
(4,189 Views)
Just delete the period at the end.
Message 6 of 12
(4,184 Views)
Dennis,
Thanks.
It works now.
Peter.
Message 7 of 12
(4,179 Views)
The link works or the assistant?
Instead of the assistant, I would suggest you look for an existing driver (Help> Find instrument Drivers) or consider using the VISA functions directly. The assistant adds a lot of overhead and drivers are not that difficult to write. Help is at http://www.ni.com/downloads/instrument-drivers/
Message 8 of 12
(4,173 Views)
The link works, not as yet a GPIB-USD converter.
IO Ass works perfectly - be it not too fast -  with all of my ( 9 ) GPIB gear thru a NI PCI 488 GPIB  card.
Not yet with a GPIB-USB converter since I still have to buy one, thats why I enquired about it on this forum.
I'll try again your advice about  drivers ( but most of the needed ones are unavailable )  and/or try directly using VISA which I didn't dare to do seriously before ( my scarce trials  before failed ).
Thanks again.
Peter.
Message 9 of 12
(4,165 Views)
Dennis,
I made a typo, not 9 but 19 NI HPIB equipment run under my NI488 PCI card + NI 120-A ( + few more GPIB / IEC 625Tektronix, Schomandl en Wavetek ).
All of them run flawlessly under IO Ass.
Now, if I change ( as I understand for speed's sake ? ) to directly using VISA functions, should I write for every of all of my gear VISA separate drivers ?
Or would one " template  " do the job for all of the gear ?
Peter.
Message 10 of 12
(4,139 Views)
