Is it possible to improve the response time of my VISA write in response to a bytes read using VISA read?
I am using a RS485- USB cable to communicate with a pic controller. I have established communication between the labview VI and microcontroller (meaning I can read packets of data from port using Visa Read and respond appropriately with Visa Write and can keep communicating). I am observing the communication on an oscilloscope. I can see read bytes and the following write bytes that I send as a response.  The gap between the two is about 2 milliseconds. I want to improve the speed with which my visa write is responding to the read bytes (so that the time gap between read and written bytes is approximately 320 microseconds). Any suggestions on how can I achieve this? Thank you.
(4,056 Views)
To get that kind of speed, you will likely need to go with an FPGA.  There are examples floating around where people used a few digital lines to do a full UART in an R-Series card with LabVIEW FPGA.
(4,045 Views)
Can you provide a couple of links? Thanks.
(4,018 Views)
