Is it possible to run my LabView program on a PC on which LabView is not install
Could you please tell me the steps to build an executable of my program that would run on a PC on which LabView is not installed
(3,419 Views)
You need the professional version or just the application builder.
They are both licensed, so you need to pay extra.
greetings from the Netherlands
(3,417 Views)
i am using right now LAB VIEW version 8.2 and I also have a licence of  this version.From that version I can make such kind of a .exe file is this version having a application builder option.
(3,401 Views)
It does not matter what numeric version you have or whether or not it's licensed. Select Help>About LabVIEW and see if it says "LabVIEW Professional Version'. If it does, then you have the ability to create an exe. If you purchased the app builder separately, the license manager (Start>Programs>National Instruments>NI License Manager) will tell you if it's licensed. Look under toolkits. If it's licensed, then follow the instructions in the on-line help for 'application builder'.
p.s. In the future, you don't want to post new questions like this to the instrument control board. Similar questions belong to the LabVIEW board as they have nothing at all to do with instrument control.
Message Edited by Dennis Knutson on 08-31-2009 10:08 PM
(3,398 Views)
