Hi bharathi,
Are you planning on using the IVI Class drivers or the IVI Specific drivers? If you use a .NET wrapper on an IVI Class driver, then you should be able to use it interchangeably with other instruments of the same class, but you will still have the setup process in MAX for all IVI drivers. If you use the IVI Specific drivers, then you will have to create the .NET wrapper again for each instrument.
Is this what you are asking about? If not, please clarify what type of driver you are wanting to use and how it would violate IVI compliance.
Have a great day!
Chris R.
