Is there a better Manual with a more specific pinout for PCI-8431/4
I need to connect this to a vacuum gauge (GP 390)and am not sure of which pins go to what.  There is no specific manual that I could find.
(3,730 Views)
Please contact National Instruments Support to obtain this information. You can create a new service request at www.ni.com/ask . Thanks!
Justin E
National Instruments R&D
(3,716 Views)
If you have NI-Serial installed on your system you can find a Serial Reference Guide in the start menu that describes the pinouts of the connectors. You can also find a copy here: Serial Quick Reference Guide
This includes pinouts for both the 10-pin connector, as well as the 9-pin DB-9 if you are using the NI-supplies cables.
-Jason S.
(3,683 Views)
