Is there a method to test the DAQ6225 sampling rate?
Is there a provision in "test panels" or anywhere else that will test the DAQ6225 sampling rate?
(3,132 Views)
What type of test do you want to perform?
If you want to measure the sample rate /clock you will need a reference.
Simply output the sample clock to a PFI and hook up an analysing instrument you trust.
Maybe more detailed information can be found in the calibration information
Greetings from Germany
Henrik
LV since v3.1
(3,119 Views)
