Is there a way to assing individual pins in Labview
I am looking to assign a certain pin on a RS-232 serial connection to a hign state, while turning the other pins to a low state. I am trying to send pulses down the cable to control a stepper motor. Is there a way to do this in Labview using the serial sommunication objects.
(3,288 Views)
You can control some of the pins using a VISA property node. E.g., "Modem Line Settings->Line CTS State".
You might also consider using the parallel port. There are some examples (in LabVIEW 7) in examples/portaccess.llb that show you how to get to the parallel port registers. From there, you'll have to know more about how parallel ports are put together, but you can control a bunch of digital lines that way. (It's easy to find information about programming the parallel port if you search the web.)
Of course, the easiest solution is probably to get a motion control board from NI. But maybe you're in it for the challenge... 😉
Brian
(3,288 Views)
