Is there any Labview program to read pusle width or jitter on Agilent54622d
I want to test the real width a clock signal by Labview6.1/Agilent54622d/GPIB-USB-B. Is there any way to control the oscilloscope to the state i required and get the result?
Thanks.
(3,173 Views)
I am not familiar with your instrument, but is this a functionality that is built into the scope? You may consult the manual for more information on the function you are looking for. There is a driver already created for the IVI driver that can be found in our insturment driver library at www.ni.com/idnet.
Hope this helps out.
Best Regards,
Aaron K.
Application Engineer
(3,173 Views)
