Is there any info on using GPIB with C#?
I want to use C# with my GPIB card but it is not clear to me how to go about it. C# does not have .h files so how would I handle these? Is there a simple example of programming this using C# anywhere?
Jesse
(3,687 Views)
The easiest way is using Measurement Studio ActiveX controls, since the .NET enviroment provides some mechanisms to wrap the ActiveX controls for the new enviroment.
There are a couple of examples on the web for the GPIB ActiveX controls in .NET:
Performing Simple GPIB Communication in Visual C# .NET with Measurement Studio Active X Controls
Simple GPIB Communication in Visual Basic .NET with Measurement
Studio 6.0 ActiveX Controls
You can also check the beta program for Measurement Studio for .NET at www.ni.com/beta.
If you are not interested in the Measurement Studio components, you can still call the GPIB functions by creating a wrapper.
You can find references on the web on how to call unmanaged code (funcitons in dlls) from .NET.
The following posting on this discussion shows a wrapper for the NI-VISA functions. You can use this as a reference to create a wrapper: Discussion Forum
DiegoF
National instruments.
(3,687 Views)
Hi, I know am replying to a 9 yr old post , my queries are similar and link to "Discussion Forum" mentioned below might be renamed.. so i cant reach it.
I have a C# project using NI VISA .
1. Can u let me know the DLLs / Assemblies tat i need to add as reference in my Project , so as i can reference the read/write functions from NI VISA.
2. When i read the NI VISA Programmer manual (as an example page 304), it mentions the C Syntax and Visual Basic Syntax , why it does not memtions the C# syntax.
3. Can u point to some examples which show read/ write scpi commands using C# using NI VISA driver?
4. Is it that " call unmanaged code (funcitons in dlls) from .NET" still holds valid after 9 years or we have something from NI which help me to use directly to call .NET functions from my C# application.
(3,261 Views)
I am on Win7 PC.
The .NET DLLs are located in C:\Program Files\National Instruments\MeasurementStudioVS2010\DotNET\Assemblies\Current
The example programs for using NI-VISA with .NET are located in C:\Users\Public\Public Documents\National Instruments\NI-VISA\Examples
You can get to the example programs from the Start Menu as well.
(3,256 Views)
