Issue with NI Drivers on AlmaLinux 9
Hello all,
I am working with AlmaLinux release 9.5 (Teal Serval) and cannot read a HV power supply attached to the computer with a RS232 connector.
Every time I try to list my instrument in a python shell I get the following
Python 3.9.21 (main, Dec  5 2024, 00:00:00)
[GCC 11.5.0 20240719 (Red Hat 11.5.0-2)] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import pyvisa
>>> rm = pyvisa.ResourceManager()
libnipalu.so failed to initialize
Verify that nipalk.ko is built and loaded.
Aborted (core dumped)
I have followed this discussion and try to repeat some steps but I did not solve my issue.
Since this is a Lab computer, I am afraid that someone installed some drivers that are not compatible with the current system since before I had no issue in seeing the power supply.
What should I do?
I have tried to install ni-daqmx, ni-visa and run dkms autoinstall that downloaded quite some stuff but nothing changed.
I have read here to make sure I have NI-KAL and looks like I do, but I do not totally get the message I have here and how this can affect me:
 yum list installed *ni-kal*
Repository ni-software-2025 is listed more than once in the configuration
Installed Packages
ni-kal.noarch                                                           25.0.0.49218-0+f66                                                           @ni-software-2025
Could someone provide any feedback? Any help is appreciated!
(1,128 Views)
Greetings,
While I don't have any instruments attached to a serial port you may want to check if you have the serial module installed. I tried something similar with an external TNC (terminal node controller) and needed to install the serial or pyserial module to get things to work.
(1,075 Views)
The NI driver isn't loading correctly with your current kernel. Try running modprobe nipalk and check dmesg | grep nipalk for errors. Also, run dkms status to confirm the modules are built for your kernel. Installing pyserial may help with RS232 communication.
(1,063 Views)
