Issue with NI-VISA 5.3 NI-I/O-Trace 3.0.2
Just installed VISA-5.3 on XP/SP3 32bit. When sending commands using the VISA test panel to a networked instrument, these commands aren't logged by NI-I/O-Trace any more. Logging for VISA calls is enabled in I/O-Trace and with VISA-5.1.2 it used to work.
Is this change intended ?
(3,331 Views)
Hi mkossmann,
do you only have this problem with this particular instrument or with all devices controlled by VISA driver?
I just ran a small test with the serial interface and VISA commands are logged in NI-I/O trace with VISA-5.3.
As far as I know there was no change from VISA 5.1 to VISA 5.3 concerning this functionality.
(3,276 Views)
