IviLxiSync
Hi guys
I'm trying to use IviLxiSync
First, i probed only with a functions. I change IviLxiSync_ by IviRFSigGen_IviLxiSync
but its not run
d:\Proyecto SEAS\IVI-EJEMPLOS\pruebasLXI\Example1.c(52): warning C4013: 'IviLxiSyncAddArmSource' sin definir; se supone que extern devuelve como resultado int
Example1 error LNK2019: símbolo externo _IviLxiSyncAddArmSource sin resolver al que se hace referencia en la función _main
Example1 fatal error LNK1120: 1 externos sin resolver
How can i integrate LXI ???
(4,116 Views)
anyone know if the ivilxisync.lib o .dll files exists???
(4,094 Views)
ave you installed IVI shared components version 1.3 or greater. The Dll should definetely be there. It  is on my machine. I think the lib and h files should be there also. If not install NI's ICP product.
(4,089 Views)
I have ivi Shared component 1.5 installed and ni icp, but there is not a ivilxisync.dll or .ib in my computer :S
There is only a IviLxiSyncTypeLib.dll that i think that can be used with ivi-COM but i dont know how to use it
I can't use ivilxisync with ivi class (ivirfsiggen for example) can you help me please???
(4,080 Views)
I was just realiably informed that there is no C Class driver for IviLXISync. I see there is a h file and it's misleading but here is no Dll or import libary
(4,060 Views)
i think that the solutions is to find ivi class drivers (ividmm, ivirsiggen, etc) that implment ivilxisync functions
but i only find that functions in specific drivers, no in class driver
What do you think??
(4,055 Views)
