IviScope_Disable
I can't show you an example but note that using the functions to read/write specific commands defeats one of the purposes of IVI in that you've now made the code instrument specific instead of genetic when you use nothing but the class drivers.
Message 11 of 13
(1,142 Views)
Hi Dennis,
Thanks for the valuable information.
I will stick to IVIScope functions as it will be generic to any instruments and only will go for IVI functions(Ivi_viWrite) if not available in the IVIScope class capablility.
But, i have seen IVI.h inside IVIScope.h. So, whether that means, IVIScope is using the functionalities through IVI functions(Ivi_viWrite).
Please correct if i am not true here.
Kiran
Message 12 of 13
(1,136 Views)
Hi Leonard/Dennis,
I was looking for some functions which can set the delay time to Custom Parmeter, P2(Lecroy 9350 scope - it was CUST2) and getting the same delay time from P2 of Xstream Lecroy scope.
I cannot find any IVIScope function which can do that.
As i really required those settings for the calibration, i think the only option i could do is go for a Ivi_viWrite().
Hope that, i am good here.
Expecting your guidance,
Kiran
Message 13 of 13
(1,122 Views)
