Jumo Dicon Touch Modbus Connection via TCP
I need to get some values from a Jumo Dicon Touch Controller via Modbus TCP into LabView.
Does anyone has an working example?
I can ping the controller. The controller is setup as master and I can not change that.
Thx for any advice.
(3,944 Views)
I'm having the same problem you had. Did you manage to solve the problem? Do you have a working example?
Thank you for your help.
(3,684 Views)
Hi ,
i need to connect to a Jumo Dicon Touch Controller via Serial or NI-Visa.
Do you have found a way to use the Dicon touch with NI ?
Best regards Juergen
(2,949 Views)
