12-12-2019 05:13 AM
Windows 10 is not recognizing my NI 9211 in my NI USB-9162 carrier.
I am just getting back into this stuff, I have been away from this for the last decade or so I am on a relearning curve, so please assume my product knowledge is a bit dated.
I installed the latest NI-daqmx, version 19.5 in my windows 10 computer today, and have started to try getting my NI measurement hardware running again. I was able to get a driver created and signed for my USB instrument rack, a NI USB-9162.
It now shows in device manager,under NI-VISA Devices, but it is named " Device model name" - this seems wrong.
In max, it's listed as USB0::0x3923::0x719A::NI-VISA-60002::RAW - this seems wrong too.
I can launch a visa test panel (see capture2.jpg attached) - this is also not very informative.
When I load my NI 9211 C Series Temperature Input Module into the USB-9162 slot, I do not see it in MAX, or device manager. It does not launch or install.
Any ideas on how to get the hardware to launch / be recognized?
attached snips are device manager,max,visa test panel respectively
Jim
Solved! Go to Solution.
12-13-2019 10:32 AM
12-13-2019 08:53 PM
Thanks, but I found that page earlier.
I followed the instruction for "Installing USB C Series DAQ Hardware". windows chimes when I plug it in, but the LED never comes on.
It's visible in device manager as "Device model name"
Its visible in MAX as "Unknown USB0::0x3923::0x719A::NI-VISA-60004::RAW"
12-14-2019 09:18 AM
OK, I was able to get this working last night.
I completely uninstalled DAQmx, and deleted the drivers for the 9126 in device manager.
Next, I reinstalled DAQmx, carefully examining the features Installed to be sure I ticked the cDAQ checkbox in the pre-install screen.
I also installed the VC 2015-2019 x64 unified runtime - not sure if this was needed...
My guess is that I missed the compact daq tickbox when I did the first install, so the drivers were not loaded.
-Jim
