KE6221, KE2400 Triggering through Labview/GPIB
Hi everyone,
I am trying to configure a Keithley 6221(current source) and Keithley 2400 (voltmeter).
I would like to use SRQ to configure the 6221 to indicate each time the current source has changed (when doing linear/custom sweeps) and that indication would trigger labview to take a reading of the voltage using the 2400.
My problem is I am having a heck of a time to configure the 6221 to indicate said sweep change and then using labview to read said data.
So I am wondering if anyone has any experience with this or has any useful links/examples.
I have gone through multiple manuals and have searched the web extensively, but I am still as lost as I was when I started.
I have looked through the IEEE488.2 command list and commands like ibwait and ibtrg seem like they would be useful, but I am still confused on how to use them.
Any help would be much appreciated.
Nathan Cernetic
(3,829 Views)
Hi
the keithley 2400 is more than a DMM, it can also source current and measure voltage.
Did you look at the triggerlink connection. That is much easier and faster than via the GPIB bus.
greetings from the Netherlands
(3,826 Views)
