KUSB 488B not operating with LabVIEW
This is really a question that you should be asking of Keithley. This is an NI forum, after all.
Message 11 of 31
(6,100 Views)
Okay ,I am sorry for the previous one.  Can you please tell me whether NI USB-GPIB converter cable which supports windows 7 (32 bit,64 bit) ,8 (32 bit,64 bit), windows 8.1(32 bit,64 bit) are available or not? If yes, could you please give the link.
Message 12 of 31
(6,092 Views)
Message 13 of 31
(6,089 Views)
Is there a possibility of adding an Alias to GPIB devices? After following these steps I shop a VISA GPIB device as I should, but it isn't showing up under "Devices and Interfaces". I'd like to add an Alias if possible.
Kellen
Message 14 of 31
(5,879 Views)
Kellen,
Please start a new thread with details about the device you do not see in MAX.  This thread is a few years old even if it is directly related to the original question.  not many of the original contributors will see your new post at least one is surely not going to respond.
Message 15 of 31
(5,876 Views)
Hi all,
I'm a new user of NI-LabView. I have established a connection between LabView and KUSB_488B, and I can see the GPIB0::INTFC &&  GPIB0::24::INSTR show up on the VISA Interactive Control. The KI-488 Configuration Utility and KI-488 Diagnostic Tool can get respond from the KUSB as well. However, I can't find it in the NI-MAX, neither communicate with KUSB through LabView. Every time I try to run the interface, it will report a visa problem which says:"The given session or object reference is invalid".
I have tried to reinstall the KI-488 Driver (NI command Compatible Drive) and LabView_2015 lots of times, but the problem still remains. And I'm sure the Driver are the latest version. I use them on the Windows7 system.
Can you tell what should I do to make MAX find the KUSB?
Tyler Wang
Message 16 of 31
(5,765 Views)
Read the section of the manual titled "using Kiethley devices with NI VISA"
Message 17 of 31
(5,759 Views)
Thank you for you reply.
I have read the manual. But there is no "GPIB Controller" under  "Devices and Interfaces" subdirectory below My System, which really troubles me, becase the GPIB interface does show up on the "VISA interactive Control", and I can write and read from the instrument without any problem. It looks like this:
screen scan
I think that's why I can't communicate with KI-488 by LabView at all.
Please help me out.
Thank you in advance.
Tyler Wang
Message 18 of 31
(5,740 Views)
Tyler,
Make sure you have uninstalled Keithleys KI-488 drivers as well, or they will take over and you won't be able to do anything.
-- Kellen
Message 19 of 31
(5,734 Views)
Only NI devices appear in NI Max.
The device appearing in NI VISA Interactive control confirms it is installed correctly and works with 32-bit NI VISA.
The question is what version of LabVIEW are you using?
Is it 32-bit or 64-bit?
Message 20 of 31
(5,730 Views)
