Keithley 182 read problem
I have a problem reading from Keithley 182 via GPIB. I have attached a VI the last but no. Could someone check and say me the reason why I cannot read it. I tried instrument from TestPoint v7. It works properly.
Thanks in advance.
(3,919 Views)
The initial 'GPIB Send Message' is certainly wrong without a message or address. Other than that, you will have to provide some details such as error codes. You might have to do most of the debug yourself since the driver is unsupported.
(3,907 Views)
I have defined the address, but still it is not working. Just WRITE and READ commands are working properly, but with configurations it is not working.
(3,901 Views)
Again, 'not working', is a poor problem description. Provide some details - at the very least any error codes you get.
(3,890 Views)
