Hi Steve,
I've checked this against a single install of TestStand 3.0, and it comes up grey as per you attachment, however it doesn't ask for the install cd on my machines (tried two).
Under TestStand 3.1, it's fine, and you have access to all the fields.
I've passed the information onto our developers, however since it's an old version, I can't make any promises of a fix, since there's the workaround youy came up with, however they will look into it.
If we do get a fix, then I'll post it back here.
Sorry.
Sacha Emery
National Instruments (UK)
// it takes almost no time to rate an answer
