Keithley 2000 - channel specific reading
Hello all,
I'm am using the Keithley 2000 + 2000-scan card via a GPIB connection.
Using the VI's in the drivers (The plug and play ones rated 3.11 on the site, with LabView 8.5)
I have only been able to read from the initiale channel of the device (the front one),
and not from any of the other channels.
From what I understand, this is because the single channel measure VI only
has the option to address that channel, or one of the calculation channels.
Is there a way to read specificaly from one of the other channels, or even
read them all, but than only display the results for some of them?
Thank you all in advance for all the help.
(3,559 Views)
Check configure scan.
With scanning you control theswitches on the section board.
good luck
greetings from the Netherlands
(3,557 Views)
