Keithley 2001 ieee754 format readings are missing "#0" header.
I'm working to convert the Keithley 2000 DMM ivi driver to support the Keithley 2001 DMM.  In the model 2001 operators manual the IEEE754 formatted responses are specified as having an ASCII "#0" header followed by 4 or 8 bytes of binary data.  This header is not appearing in the data returned by the meter.  I have two meters with different fw revision (B15 and B16) that both behave this way.  Does anyone know if this is a mistake in the manual or did I miss a configuration setting?
I am the founder of CnCSoftwareSolutions. When not cleaning up baby drool, I write about test data or work on Vision, a tool for understanding your test data. Visit me at www.cncsoftwaresolutions.com
(3,622 Views)
Have you tried contacting Keithley?  They would probably have a better idea about this issue.
Emilie S.
(3,608 Views)
